CreateCache Error [Web.Exception]
2321
7
11-29-2012 09:11 AM
Andréde_Mattos_Ferraz
I have 2 servers, 10.0 and 10.1, and i have one mobile application. The app works for mobile services 10.0 and not works to mobile services 10.1. I already checked the settings of both services and everything seems normal. Have any other configuration to be done in MobileServices 10.1?
private void syncFilter()
            mobileCache1.StoragePath = Environment.GetFolderPath(Environment.SpecialFolder.Personal) + @"\MapCache";
            //SERVICE 10.1 not work on create CACHE - WEB.EXCEPTION
            //mobileServiceConnection1.Url = "http://srv508:6080/arcgis/services/CENIBRA/UsoSoloMobile/MapServer/MobileServer";
            //SERVICE 10 WORK all app....
            mobileServiceConnection1.Url = "http://srv514/arcgis/services/FIBRIA/mob_parcel/MapServer/MobileServer";
            mobileCache1.DeleteCache();
            MobileCacheSyncAgent mobilesync = new MobileCacheSyncAgent(mobileCache1, mobileServiceConnection1);
            MobileCacheSyncResults mobileResults = new MobileCacheSyncResults();
            mobileServiceConnection1.CreateCache(mobileCache1);
            mobileCache1.Open();
            MobileCacheSyncAgent agent = new MobileCacheSyncAgent(mobileCache1, mobileServiceConnection1);
            //bottom left , top right
            Envelope env = new Envelope(new Coordinate(-40.000173444, -19.557481484 ), new Coordinate(-39.989017249, -19.549518499));
            agent.DownloadExtent(env, 0, 0);
StackTrace
"at ESRI.ArcGIS.Mobile.MobileServices.BinaryWebService.ExecuteRequest()\r\nat ESRI.ArcGIS.Mobile.MobileServices.MobileServiceConnection.ExecuteRequest()\r\nat ESRI.ArcGIS.Mobile.MobileServices.MapDocumentConnection.RequestSchema()\r\nat ESRI.ArcGIS.Mobile.MobileServices.MapDocumentConnection.CreateCache()\r\nat ESRI.ArcGIS.Mobile.MobileServices.MapDocumentConnection.CreateCache()\r\nat ESRI.ArcGIS.Mobile.MobileServices.MapDocumentConnection.CreateCache()\r\nat ESRI.ArcGIS.Mobile.MobileServices.MapDocumentConnection.CreateCache()\r\nat SmartDeviceProject1.Form1.syncFilter()\r\nat SmartDeviceProject1.Form1.Form1_Load()\r\nat System.Windows.Forms.Form.OnLoad()\r\nat System.Windows.Forms.Form._SetVisibleNotify()\r\nat System.Windows.Forms.Control.set_Visible()\r\nat System.Windows.Forms.Application.Run()\r\nat SmartDeviceProject1.Program.Main()\r\n"
MikeDuppong
André, did you resolve this issue?
I'm coming up with the same.
Remove all references of Arcgis SDK 10 (MOBILE, ArcObjects ...) and SDK 10.1.Then reinstall SDK 10.1 e SDK MOBILE 3.1 . Work for me.
MikeDuppong
Ah, OK.
My situation is that I can't get 10.0 on the mobile to talk with a 10.1 server.
Thanks for your response.
The url for acess services 10.1 is diferent:
<!--Mobile 3.1(10.1)-->
"http://srv514/arcgis/rest/services/FIBRIA/mob_parcel/MapServer/MobileServer"
<!--Mobile 10.0-->
And i think, if you want access a service 10.1 you will need upgrade your app to use SDK MOBILE 3.1 (dll)...
Try just substitute url of your service and try run..
MikeDuppong
Right, I realize the URL has changed, but still no luck.  Just get a nondescript WebException when attempting a mobileServiceConnection.CreateCache() call.
You will need change your SDK to a newer (3.1).
VickyS
I'm using ArcGIS Mobile 10.1.1 and the latest SDK. Did anyone solve this?
Thank you
