Create Mobile Map tool not working
641
06-25-2013 05:01 AM
DennisO_Heney
Hi Everyone,
I've been having a bit of trouble using the 'Create Mobile Map' geoprocessing tool in ArcGIS Desktop 10.  I'm pretty new to using ArcGIS Mobile, but this problem I'm having seems to be much more of a software issue than a user issue.
Basically, whenever I run the tool, I'm able to pick the Input map document, output project folder, and all my layers just fine, and the tool will then create all the files.  The problem is that ArcGIS continues to show the process as running in the bottom of the window, even with a 100% completion status.
I know it's created all of the necessary files, I can go into the project folder and see the mobile cache, and a mobile map (within the cache, a .db, .db-journal, and three .bin files).
I have also tried just importing the mobile cache into the mobile project center, but I keep receiving an error message saying, "Error: Invalid File or Corrupted File"
Does anyone have any suggestions?  Any help at all would be greatly appreciated.
Some potentially useful info:
  • ArcGIS Desktop 10 build 2800
  • ArcGIS Mobile 10 build 2550
  • All data must be transfered via USB (No ArcGIS.com or Server)
  • Deploying mobile map to Trimble Geoexplorer XH
Cheers,
Dennis
