Arcgis for Windows mobile 3.1 Catch EditFeatureAttributesPage click ok event
784
04-10-2013 02:56 PM
JérémiePedoia
I wonder how to handle click ok event from every EditFeatureAttributesPage.
I can handle the click ok event from the ManageEditsTask (ESRI.ArcGIS.Mobile.Client.Tasks.ManageEdits.ManageEditsTask.EditFeatureAttributesPage) with this code:
    protected override void OnOwnerInitialized()
        // Make sure we are on the UI thread because getting the
        // EditFeatureAttributesPage may cause it to be created, which can only
        // occur on the UI thread.
        if (!MobileApplication.Current.Dispatcher.CheckAccess())
            MobileApplication.Current.Dispatcher.BeginInvoke((ThreadStart)delegate()
                OnOwnerInitialized();
            return;
        // Listen to the event from the edit feature attributes control from the
        // View Updates page.
        ManageEditsTask editTask = MobileApplication.Current.FindTask(typeof(ManageEditsTask)) as ManageEditsTask;
        if (editTask != null)
            _editAttributesPage = editTask.EditFeatureAttributesPage;
            _editAttributesPage.ClickOk += new EventHandler(_editAttributesPage_ClickOk);
But it's apparently limited to the manage edits task ans synchronyze task.
Is it possible to catch the same event from the Identify task? From the search task?
Is there a way to catch click ok from any of EditFeatureAttributesPage?
I hope I am clear.
Thank you for your help.
Best regards, J.
