ArcGIS for Mobile Server Synchronization
3126
10-21-2013 05:48 PM
JonathanAtienza
Good day,
I just want to Ask what can be a proper workflow for synchronization process between Arcgis for mobile and Arcgis server because i'm having a problem in uploading the data from the field to the server.
thank you
BryanBingham
If you are having problems uploading changes from the mobile device back through server and into SDE.  I had this issue with ArcGIS Mobile for 10.0 build 2550, i have yet to have this issue with the 10.1 suite.
Try these steps:
1) Stop the mobile service through Catalog or AGS Manager
2) Removing the spatial index on the layer that is failing to upload in Catalog
3) Re-start the mobile service
4) Try the Post/Syncronization again; if it works, stop the service and re-create the spatial index in SDE if it doesn't work see next step.
5) Get Creative, there is an app that was created that can move the mobile cache to a series of shapefiles that you can use to append, delete and insert all of the data collected in the field.
Hope this helps,
Bryan
