Add base map error : Key not valid for use in specified state
2892
07-15-2013 06:08 AM
NicolasBiboba
One day, out of the blue, I had this error when I clicked on Add BaseMap from Catalog :
"key not valid for use in specified state".
In fact, it does not matter since I can add basemap even though I have this error message. But still quite strange.
But the real problem came after I had the  StreetMap data. In arcGIS for Mobile, I have the basemap loaded and working but the routing task is not working anymore :
"Specify a valid StreetMap dataset as the application parameter".
Conclusion : I can't use the routing task.
I don't know if it these 2 errors are linked but if you have any idea please feel free to share ! I tried remove and copy once again my StreetMap Data but it did not change anything.
Nicolas
