Why doesn't the Map Web Part zooms automatically to a list?
467
10-05-2012 01:02 AM
PhilippeDerynck
I've created a spatially enabled list with the geocoding workflow. When I check a list item, it's correctly geocoded and the map in "ArcGIS Location" zooms in.
I've added a Map Web Part and added the list with browse. The maps doesn't automatically zooms in, I have to click "GoTo".
Also when I add a new list item, the map doesn't refresh the extent.
Any ideas?
Is it always necessary to add the list (browse) to the map? Is it possible to make the Map Web Part aware of a spatially enabled list when added to a page? or when inserting a list Map Web Part in edit mode. Normally it's possible to connect a list to an other Web Part via "Connections" but it's grayed out when only a Web Map Part is in the page.
Thanx
