System Check Error on Install: Database Connection Problem
1536
01-04-2011 10:27 AM
CorbanDavies
During the second step of the system check (ArcGIS Mapping for SharePoint 2.0) I am getting a "SharePoint was unable to connect to the database" error.
I am attempting the install on a Server 2008 R2 machine.
Any thoughts?
JanBorovanský
Hi Corban,
at first verify you are not login in the sharepoint central administration.
Second - try run the Setup.exe as 'Run as administrator'.
Third (if still not resolved) - start the IIS Manager, go to Sites and start all sites except Default Web Site.
Then try again and run the Setup as Run as administrator.
I have run into the same issue several times and above steps helped me.
Regards
Jan
