Support for wic_System_GPS_Latitude and wic_System_GPS_Longitude column types
1133
10-27-2013 11:47 PM
RobDunfey
If I add columns named wic_System_GPS_Latitude and wic_System_GPS_Longitude to my SharePoint picture library, SharePoint automatically extracts the location of a geotagged photo into these columns.  I want to map this library on the ArcGIS SharePoint web map part, this doesn't appear to work with the 2.1 version of the controls, the list used by the Picture library isn't available when I browse the SharePoint site to add a layer in the web map part, I wanted to know if it works with the latest version of the web parts?
ThomasBohnert1
Hi Rob, did you try to add a column with the Esri Maps Location type?
Normally only those spatially enabled lists will be offered within the map web part.
But I guess you have to rename the coordinate columns to a recognized option first (see also http://forums.arcgis.com/threads/94331-Adding-Sharepoint-list-data-to-Esri-Maps-webpart).
