SharePoint 2010, Windows Server 2008/R2 cannot add both web parts
5608
14
06-23-2010 10:44 AM
ToddCrenshaw
I'm running Windows Server 2008/R2 with SharePoint 2010 Enterprise. I have installed the ArcGIS Geolist Web Part and ArcGIS Map Web Part on the main portal. Going to a site and selecting edit page I see the "Add a Web Part" links in the zones on the page. I click on the link and selecting either ArcGIS web part places it in the page. After doing this the page editing controls become inactive (grayed out). The Edit button loses its icon altogether. Clicking on the "Add a Web Part" in any zone results in absolutely nothing happening. After adding the first web part, at the bottom left of IE I get a warning "Done, but with errors on page." I just go up to the pull down arrow of the ArcGIS web part and select Delete. Once the web part is deleted the pages editing controls on the ribbon become active again. I can add other web parts, as many as I want without any problem. This only occurs when I add in either ArcGIS web part. Any help to resolve this problem would be appreciated.
MarkWiggins
Did you add them to a web part page or a wiki page?
RichZwaap
Version 2.0 of ArcGIS Mapping for SharePoint has been released.  2.0 is built specifically for SharePoint 2010 and includes many new features and enhancements.  If you are using SharePoint 2010, please uninstall version 1.1.1 and go get version 2.0 from the Resource Center - http://help.arcgis.com/en/webapps/sharepoint.
João_PauloMenezes
I had the same "Expected '('" problem with version 1. I was waiting for version 2 to be released, hoping that it would solve the problem.
I have now just upgraded the ArcGIS Mapping for SharePoint version to 2.0 and I still get the same Javascript error. Can someone else confirm this?
RichZwaap
João - you should not be seeing that issue with 2.0.  You need to uninstall version 1.x and remove the 1.x configuration lists (you can find a list of the 1.x configuration lists here).  Note that your 1.x web parts will no longer work - you will need to create new Map Web Parts for version 2.0.  Also, at version 2.0, there is no longer a Geolist Web Part; the attribute table functionality has been embedded within the Map Web Part.
Hope this helps.
João_PauloMenezes
Rich, you are correct. I retracted the solution and removed all related lists and then reinstalled and now it's working fine.
Thanks!
