Save map configuraton
1217
01-13-2012 02:12 PM
JTessier
Once all the layers are setup for a map, can you access/save that configuration?
DerekLaw
Esri Esteemed Contributor
Hi J,
Once you've setup your configuration(s) for the Map Web Part and save your settings, these will persist in the SharePoint page.
Is that what you're asking?
JTessier
Hi Sorry, I wasn't notified of your response.
No, I need to transfer the settings from my dev machine to production, and would like to know where the file is that records those settings, so i don't have to redo it on another server or site.
J
DerekLaw
Hi J,
... I need to transfer the settings from my dev machine to production, and would like to know where the file is that records those settings, so i don't have to redo it on another server or site.
I believe you can save the SharePoint site as a template and use that as the basis to create a new SharePoint site.
Hope this helps,
