Problems with Sharepoint and Mapping Base Maps list ?
1285
10-21-2010 06:06 AM
IanVaughan
Hi
I am using Sharepoint Foundation 2010 and have just installed the ArgGis Mapping for Sharepoint and installed it onto the server.  I can add the web part into a page but.....
When I drill down into Site Actions > Site Settings > for some reason I am not seeing the option ArcGIS Mapping Administration heading?
Any ideas on what is going wrong?  as I am trying to change the basemaps as per the guide at
http://help.arcgis.com/en/webapps/sharepoint/help/ConfiguringBasemaps.html
TIA
NikShampur
Are you a site administrator on the site or just a site contributor.
you need to be a site administrator in order to see the Administration section
IanVaughan
Thanks that now works!
The other problem I am having is with the actual web part, I don't seem to see the same options that are available on the ESRI help guide for Sharepoint.
For example in the ribbon toolbar for this webpart I cant see the 'Add Content' option under the Application tab or the symbols tab?
What I am trying to do is add the British Geological Survey Geology base map onto the web part
http://www.arcgis.com/home/item.html?id=e5e5ea8118354f239561be0cd5775c8a
The other query is what address would I need to use to call this base map data?
TIA
NikShampur
The "Add Content" functionality along with the other buttons need to be enabled for run-mode by editing the webpart and adding the buttons to the ribbon. The "Manage Ribbon" button is what you would use to achieve this.
Hope this helps.
