prerequirement for arcGIS mapping for Sharepoint and how to test it
3883
09-06-2011 11:24 AM
garyshi
I download arcGIS mapping for Sharepoint v2.0 and install it. But don't know how to use it. I didn't find if I need to install InfoPath and version? It was installed in vm without internet and look like map isnot working, it required to connect to internet ? Where I can get step by step instruction for how to use it after installation ? And step by step instruction to create one page, and then add this mapping web part, using existing map, or example map. I have another vm which has sharepoint 2010 and it has standalone installation, not farm and used local domain, this environment also work for ArcGIS web part ? thanks. Gary
DerekLaw
Esri Esteemed Contributor
Hi Gary,
Please review the help documentation here:
ArcGIS for SharePoint Resource Center
Hope this helps,
garyshi
Hi Law,
Thanks for your information. I found this help, but I can't find answers:
1. if need to install InforPath. If yes, what is verison
2. If required connect to Internt ? If no Internet, how to make it work
3. I got error and could not load map when I tried to add arcGIS web part into one page. I will attach the detail error. This is why I am thinking I may have missed some components when installed.
thanks
Gary
DerekLaw
Hi Gary,
A1. InfoPath is not required for ArcGIS for SharePoint to work.
A2. You will need an internet connection if you want to access and use ArcGIS Online basemaps, locators, and geometry services. Alternatively, if you do not want to access the internet, then you can access these types of resources from your own ArcGIS Server/ArcGIS Portal instance on your internal network. This can be enabled by modifying the configuration files in the document libraries and lists. Please review the help doc in the resource center for details.
A3. You will need to provide more details.
Hope this helps,
garyshi
In Welcome to ArcGIS Mapping for Sharepoint, it require .net Framework3.5 with sp1. I have .net Framwork3.5, without sp1, but I have .net framework 4.0. My OS is windows server 2008 64 bit with sharepoint 2010. Do I have to install .net framework 3.5 service pack 1 ?
thanks
Gary
DerekLaw
Hi Gary,
Do I have to install .net framework 3.5 service pack 1?
Yes, I would install service pack 1.
Hope this helps,
