Geocoding Workflow failed
3231
10-22-2012 05:24 AM
DeanGross
The geocoding workflow is failing with the following error:
Your WorkFlow failed: Unable to connect to the remote server. System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 184.73.242.18
How can i fix this?
TIA
Dean
KatherineDalton
Hi Dean,
I don't know if you were able to resolve this issue, but are you behind a firewall? Can you hit our ArcGIS locator (url is in the locators list) rest endpoint in a browser? Or are you using your own locator? Ifyou cannot hit the locator in a browser it might be a good idea to check with your IT department.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
DeanGross
I have not been able to resove this issue. I have a support ticket open. I can hit the ArcGIS locator. I can geocode individual items. The problem only occurs when the workflow tries to geocode an item.
