Failed to set domain when copying subtype
1611
11-23-2012 07:00 AM
ChristineGo
Dear All,
I've written the following code trying to copy the subtypes of a feature class, but got the following error message in the set_Domain method, could anyone help point out what's wrong?
Error message: "This database does not support null default values."
Program:
    private bool copySubTypes(IFeatureLayer pFeatureLayer, IFeatureClass fgdbFeatureClass, IWorkspace fgdbWorkspace)
                if (pFeatureLayer == null || pFeatureLayer.FeatureClass == null) return true;
                ISubtypes subtypes = (ISubtypes)pFeatureLayer.FeatureClass;
                ISubtypes fgdbSubTypes = (ISubtypes)fgdbFeatureClass;
                IWorkspaceDomains fgdbWSdomain = (IWorkspaceDomains)fgdbWorkspace;
                if (!subtypes.HasSubtype) return true;
                fgdbSubTypes.SubtypeFieldName = subtypes.SubtypeFieldName;
                IEnumSubtype enumsubtype;
                int subtypeCode;
                string subtypeName;
                IFields pFields = pFeatureLayer.FeatureClass.Fields;
                enumsubtype = subtypes.Subtypes;
                enumsubtype.Reset();
                subtypeName = enumsubtype.Next(out subtypeCode);
                while (subtypeName != null)
                    fgdbSubTypes.AddSubtype(subtypeCode, subtypeName);
                    for (int iCnt = 0; iCnt < pFields.FieldCount; iCnt++)
                        string sFieldName = pFields.get_Field(iCnt).Name;
                        object defVal = subtypes.get_DefaultValue(subtypeCode, sFieldName);
                        if (defVal.ToString().Length > 0)
                            fgdbSubTypes.set_DefaultValue(subtypeCode, sFieldName, defVal);
                        IDomain pDomain = subtypes.get_Domain(subtypeCode, sFieldName);
                        if (pDomain != null)
                            IDomain fgdbDomain = fgdbWSdomain.get_DomainByName(pDomain.Name);
                            if (fgdbDomain == null)
                                return false;
                            else
                                fgdbSubTypes.set_Domain(subtypeCode, sFieldName, fgdbDomain);
            return true;
Bila
KatherineDalton
I think you may have accidently posted in the wrong forum?
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
