Esri Maps configuration
4175
02-28-2014 02:30 AM
astmapastmap
I've configured client and server according to the bobj intallation guide. After i create dashboard and add esri map component, i bind query objects. I also launch esri maps designer with my ArcGis online user. However i cant see query objects in esri maps designer. i cant find where i did mistake.
Does anyone have a suggestion?
thanks.
ShirleyBaffoe
Hello,
You will need to go through the Add data > from Business System workflow in order to see your query objects and visualize your data on the map. Please refer to the documentation http://location-analyticsdev.arcgis.com/en/maps-for-sap-bobj/design-maps/add-sap-businessobjects-dat....
Hope this helps.
astmapastmap
Hello,
After setting authorization for connect to argcis online adresses, the problem was solved.
Moreover BI launchpad on internet explorer 8 can not run  Esri component for BO dashboard. i cannot try new version of explorer but it is run with chrome.
ShirleyBaffoe
Hello Astmap,
I am happy you managed to correct the problems you were having. At the moment, we do not actively support IE8. Please refer to our help for more information on our supported platforms.
'>http://location-analytics.arcgis.com/en/maps-for-sap-bobj/install-and-configure/supported-environm...
. You can submit an enhancement request to the team for IE8 support through ideas.arcgis.com. Click on the Post button and submit your request.
Please contact us if you have any other issues.
ArjunKT
Hello,
Hi How did you do this ?Please explain me in detail.
