Error to open launch Esri Map Designer
5245
06-30-2014 05:46 AM
by Anonymous User
Not applicable
Original User: lcfilho
I'm having trouble opening the launch esri Map Designer, I have done the configuration file em4bobj.properties still does not open. see the attachments.
Best Regards,
Luiz Filho
by Anonymous User
Not applicable
Original User: sbaffoe
Hello Luiz,
You need to modify the server name from localhost to the name of your BusinessObjects server on which you deployed the Esri Maps for SAP BusinessObjects server components. e.g. http://mycompany.com:8080. Also if your server is running on a port other than 8080, change the port number as well.
For more information on Installing the client-side components kindly refer to the online help http://location-analytics.arcgis.com/en/maps-for-sap-bobj/install-and-configure/install-client-side-...
Hope this helps.
Shirley
LuizFilho
I did all procedures. Have changed from localhost to the server name, same error. See the attachment.
Hello Luiz,
Hope this helps.
Shirley
by Anonymous User
Not applicable
News about error?
Thanks
by Anonymous User
Not applicable
Hello Luiz,
I noticed from the screenshot you attached that the em4bob.properties file is not in the correct path. Please nagivate to the the assets sub-folder within the Xcelsius folder and create a new subfolder named em4bobj.
e.g. C:\Program Files (x86)\SAP BusinessObjects\Xcelsius 4.0\assets\em4bobj
Copy the em4bobj.properties file to the newly created em4bobj folder. You should now be able to launch the Esri Maps Designer.
Shirley
LuizFilho
Great! Sorry about that.
Hello Luiz,
Shirley
