Error Installing ArcGIS Mapping for Sharepoint
2462
01-31-2011 11:52 AM
HansDorries
All the checkmarks in the verfication process are in green; the installation starts but then I get this error:
***** SOLUTION DEPLOYMENT *****
***** ERROR *****
ESRI.ArcGIS.Mapping.SharePoint.Installer.InstallException ---> ESRI.ArcGIS.Mapping.SharePoint.Installer.InstallException
   at ESRI.ArcGIS.Mapping.SharePoint.Installer.InstallProcessControl.WaitForJobCompletionCommand.Execute()
   --- End of inner exception stack trace ---
   at ESRI.ArcGIS.Mapping.SharePoint.Installer.InstallProcessControl.TimerEventInstall(Object myObject, EventArgs myEventArgs)
***** FEATURE DEACTIVATION *****
***** SOLUTION RETRACTION *****
Any suggestions?
Thanks!
keobakileMothobi
I have a similar problem, anyone out there to assist,
ShwetambariGulhane
Try doing the manual deploy of the solution file.
Follow the steps below to deploy the solution file:
1) First, uninstall the solution file using the installer.exe
2) Restart the SharePoint machine
3) At the command line prompt, manually deploy the solution file by using the following commands
stsadm -o addsolution -filename \ESRI.ArcGIS.Mapping.SharePoint.wsp
stsadm -o deploysolution -name ESRI.ArcGIS.Mapping.SharePoint.wsp -url http://:>
Note: change the path to  "%COMMONPROGRAMFILES%\microsoft shared\web server extensions\12\bin" to access the stsadm.exe
Documentation regarding the commands for reference
http://technet.microsoft.com/en-us/library/cc261956%28office.12%29.aspx
http://technet.microsoft.com/en-us/library/cc262459%28office.12%29.aspx
http://technet.microsoft.com/en-us/library/cc263162%28office.12%29.aspx
