Displaying multiple sets of coordinates in SharePoint List
1202
09-05-2013 07:17 AM
JoshuaWhitaker
We just installed the "Esri Maps for SharePoint 2010 v3.0" on SharePoint Foundation 2010.
I have a list with 4 sets of Latitude and Longitude data and if possible wanted to display all of them.
When attempting to create a second "Esri Maps Location" column, I receive the message "Only one Location column can be added to a list."
Is there another method or approach I could take to accomplish?
Thank you in advance...
KatherineDalton
Hi Joshua,
As you've seen, we only support one Esri Maps Location field per list. There's no workaround for that. You might be able to (using the Esri Maps Web Part) map one set of coordinates and then share that layer out to AGOL thereby creating a Feature Service which you could add back in...but then you've lost all the benefits of the connection of a SharePoint list and the map web part. You'd have turned your data into static data at that point. Maybe others have suggestions. 🙂
Hope that helps,
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
