Custom unique value renderer is not showing in Sharepoint
2263
03-01-2012 11:40 AM
AzizaParveen2
I developed a custom tool and a custom behaviour using ArcGIS API for Silverlight and I have created a custom unique value renderer
in the behavior.cs file where I also define my feature layer and intialized it but I have created the symbol in the user control.resources in XAML file and I accessed them from the code behind as suggested in the sharepoint Help document, and it works fine when I debug it in using visual studio template, but when I add it to Sharepoint the symbol is not showing.
Here is the code in Behavior.cs
protected override void OnAttached()
            base.OnAttached();
           UniqueValueInfo uValinfoApproved = new UniqueValueInfo();
           uValinfoApproved.Symbol = locateAddDialog.Resources["GreenStickPinSymbol"] as Symbol;
           uValinfoApproved.Value = "Approved";
           UniqueValueInfo uValInfoDenied = new UniqueValueInfo();
           uValInfoDenied.Symbol = locateAddDialog.Resources["RedStickPinSymbol"] as Symbol;
           uValInfoDenied.Value = "Denied";
           UniqueValueInfo uValInfoPending = new UniqueValueInfo();
           uValInfoPending.Symbol = locateAddDialog.Resources["YellowStickPinSymbol"] as Symbol;
           uValInfoPending.Value = "Pending";
           UniqueValueRenderer PlanStatusRenderer = new UniqueValueRenderer()
               Field = "PLAN_STATUS",
               DefaultSymbol = locateAddDialog.Resources["YellowStickPinSymbol"] as Symbol
            PlanStatusRenderer.Infos.Add(uValinfoApproved);
            PlanStatusRenderer.Infos.Add(uValInfoDenied);
            PlanStatusRenderer.Infos.Add(uValInfoPending);
            if (locateAddDialog == null)
                locateAddDialog = new LocateAddressDialog();
            Map currentMap = MapApplication.Current.Map;
            if (currentMap != null)
                if (prePlanfs == null)
                    prePlanfs = currentMap.Layers["prePlanAdd"] as FeatureLayer;
                    if (currentMap.Layers["prePlanAdd"] == null)
                        prePlanfs = new FeatureLayer();
                        prePlanfs.Url = "http://rrugisprod-w1/RRUArcGIS/rest/services/test_preplan/FeatureServer/0";
                        prePlanfs.OutFields.AddRange(new string[] { "OBJECTID_1", "OBJECTID", "BATT", "PRA", "XCOORD", "YCOORD", "STREET_ADD", "JPEGS", "PLAN_STATUS" });
                        prePlanfs.ID = "prePlanAdd";
                        prePlanfs.Renderer = PlanStatusRenderer;
                        //SimpleRenderer simpleRenderer = new SimpleRenderer();
                        //simpleRenderer.Symbol = locateAddDialog.Resources["SelectedMarkerSymbol"] as Symbol;
                        //prePlanfs.Renderer = simpleRenderer;
                        prePlanfs.Initialize();
                        prePlanfs.InitializationFailed += new EventHandler<EventArgs>(prePlanfs_InitializationFailed);
                        currentMap.Layers.Add(prePlanfs);
             //MapApplication.Current.ShowWindow("Locate Address", locateAddDialog, false);
             prePlanfs.MouseLeftButtonUp += new GraphicsLayer.MouseButtonEventHandler(prePlanfs_MouseLeftButtonUp);
Code in XAML file
<UserControl.Resources>
        <!-- Yellow Symbol for Pending Status-->
        <esri:PictureMarkerSymbol x:Key="YellowStickPinSymbol">
            <esri:PictureMarkerSymbol.ControlTemplate>
                <ControlTemplate>
                    <Canvas>
                        <vsm:VisualStateManager.VisualStateGroups>
                            <!--Will show the ellipse-->
                            <vsm:VisualStateGroup x:Name="SelectionStates">
                                <vsm:VisualState x:Name="Selected">
                                    <Storyboard RepeatBehavior="ForEver">
                                        <DoubleAnimation BeginTime="0" Storyboard.TargetName="ellipse" Storyboard.TargetProperty="(UIElement.RenderTransform).(ScaleTransform.ScaleX)" From="1" To="3" Duration="00:00:01" />
                                        <DoubleAnimation BeginTime="0" Storyboard.TargetName="ellipse" Storyboard.TargetProperty="(UIElement.RenderTransform).(ScaleTransform.ScaleY)" From="1" To="3" Duration="00:00:01" />
                                        <DoubleAnimation BeginTime="0" Storyboard.TargetName="ellipse" Storyboard.TargetProperty="(UIElement.Opacity)" From="1" To="0" Duration="00:00:01" />
                                    </Storyboard>
                                </vsm:VisualState>
                                <vsm:VisualState x:Name="Unselected">
                                 </vsm:VisualState>
                            </vsm:VisualStateGroup>
                            <vsm:VisualStateGroup x:Name="CommonStates">
                                <!--Will not show the ellipse-->
                                <vsm:VisualState x:Name="Normal">
                                    <!--<Storyboard RepeatBehavior="ForEver">
                                        <DoubleAnimationUsingKeyFrames Storyboard.TargetName="ellipse" Storyboard.TargetProperty="Opacity">
                                            <EasingDoubleKeyFrame KeyTime="0" Value="0"/>
                                            <EasingDoubleKeyFrame KeyTime="0:0:1" Value="0"/>
                                        </DoubleAnimationUsingKeyFrames>
                                    </Storyboard>-->
                                </vsm:VisualState>
                                <vsm:VisualState x:Name="Mouseover">
                                    </vsm:VisualState>
                        </vsm:VisualStateManager.VisualStateGroups>
                        <Ellipse Height="20" Width="20" Canvas.Left="-5" Canvas.Top="-5" RenderTransformOrigin="0.5,0.5" x:Name="ellipse" IsHitTestVisible="False" Opacity="0">
                            <Ellipse.RenderTransform>
                                <ScaleTransform />
                            </Ellipse.RenderTransform>
                            <Ellipse.Fill>
                                <RadialGradientBrush>
                                    <GradientStop Color="#FFFFA07A" />
                                    <GradientStop Color="#FFFFFFE0" Offset="0.25" />
                                    <GradientStop Color="#FFFFA07A" Offset="0.5" />
                                    <GradientStop Color="#FFFFFFE0" Offset="0.75" />
                                    <GradientStop Color="#FFFFA07A" Offset="1" />
                                </RadialGradientBrush>
                            </Ellipse.Fill>
                        </Ellipse>
                        <Image Height="20" Width="20" Canvas.Left="-5" Canvas.Top="-5" x:Name="YellowStickPin" Source="/PrePlan_012412.AddIns;component/Images/YellowStickpin_bgtp.png"></Image>
                      </Canvas>
                </ControlTemplate>
            </esri:PictureMarkerSymbol.ControlTemplate>
        </esri:PictureMarkerSymbol>
            </UserControl.Resources>
I just find out that our SharePoint site is running on .Net Framework 2.0, if it helps.
I will really appreciate any help.
Thanks so much.
by Anonymous User
Not applicable
You certainly can access symbols from control.resources.  Where are you defining the red and green stick pin symbol within your XAML, as I don't see that in your sample?
Regards,
Doug C.
Esri Support Services
