Cannot able to connect map for office excel plugin to the portal
4096
11-21-2013 11:49 PM
NitinShinde
I have following configuration done on poratside
1) CA SSL certificate is installed.
2) accepts only HTTPS requests
3) Active directory integration done on portal.
when I am putting following URL in map for office arcgis connection
https://<servername.domainname.com>/<webadaptername>
it gives following error
[ATTACH=CONFIG]29283[/ATTACH]
suggestions plz..
thanks in advance
WilliamCraft
Does the URL you are inputting actually resolve correctly from the same client that is running Excel?  Please verify that is the case via your web browser.
Within IIS for the web adaptor, under Authentication is Windows Integrated Authentication set to 'enabled' and Anonymous Authentication set to 'disabled'?
Are you certain that your Windows AD account is set up within Portal to begin with?  To verify, go to Portal with either your initial administrator account or your own AD account and click on My Organization to see if your AD account got set up.  The AD accounts get added to Portal upon the first initial login request from an AD account.
Try EMO again to see if it works under these conditions.
