Set Visibility range on basemap
1367
01-30-2023 11:29 PM
Matgo
Hello, I have made parkings lots where people in my organization can see who have leased on a specific parking lot. I've done points on ArcMap, took the coordinates and put them on a table on ArcGis Excel. Then I share it through instant map so everyone in my organization can have it online. I have two problems with this:
1. The map show the earth, how can I set the visibility range on ArcGis Excel so it zoomed in directly to the parking lots and not showing the earth?
2. Whenever a person in my organization press one of the points it show to much information like rowid, the xy coordinates, how can I make those dissapear?
Thank you in forward 🙂
David_Brooks
MVP Regular Contributor
@Matgo , these settings are set in the Web Map itself, not the Instant App.
1. you can set the default extent of the web map in the web map settings:
2. you can edit the popup configuration in the web map by updating in map viewer and then removing fields from the visible list:
David
..Maps with no limits..
Matgo
Hello, thank you very much for replying!
1. I can change the visbility range on web map but the issue is when I update my excel layer, it will zoom out the world, is like the excel layer overwrite the setting for the web map. I try to do like the picture you sent me on the layer but it will still be the same.
2. Thank you, It worked so now I have the information I want.
