I thought this used to work but now the add data to excel button is greyed out if the user is a guest. Same layer works if I log in. I can add to the map side but the data side no.
Is this a change? Do you need an account to add? I tried a free account also and a no go.
thanks
Hey there @DougBrowning,
We did make some improvements to better align with ArcGIS Online users. Note the following updates:
The greater conversation was sparked by two bug logged by Tech support as BUG-000170463 and BUG-000172999. In addition, you may recall sometime in late 2024, ArcGIS Online updated their user types/roles, therefore, our components followed suit. See roles for additional context.
Hope this helps!
-SC
All our services are read only no editing. We just wanted to be able to have the public add our ArcGIS Hub data and see the table in Excel. I thought it used to work. Bummer. thanks
You may have seen my other post that when we try to do this between portals pass through Auth is not working correctly.
