ArcGIS for Excel - new spatial filter analysis failed
1202
07-16-2024 10:49 AM
EileenTeasdale
Tested this feature out and it keeps failing.  How do we troubleshoot the cause of this failure; there is no information aside from error saying "spatial filter failed"?
ShannonCardoza82
Good morning @EileenTeasdale, Thank you for reaching out. After reading your questions, I have posted a more in depth blog that may be helpful. Here is the link!
Please let me know if you have any other questions or troubles.
All the best,
SC
EileenTeasdale
Hi, I was doing the items you talk about in the blog.  I seem to have troubleshooted the problem and posted my solution below.
EileenTeasdale
It appears that the problem has to do with my Result Layer Name.  If I have spaces in the name I get the spatial filter error.  If I remove the spaces or use underscores in the name instead then the analysis works.
JosephGenther
I'm getting an error attempting to filter points by which ones fall within a ring buffer that I also created in the same Excel tool.
Ensuring the name of the output feature layer has no spaces didn't resolve this issue.
