We are pleased to share the latest update for ArcGIS for Excel 2023.1.0.0.19 which has bug fixes and quality of mapping improvements.
Updates should be seen at once. If you do not see the changes, you may need to refresh or close Excel and restart it.
Several bugs have been fixed, including:
- Fixed "Date" as the default selection instead of "Double” when inserting a new column.
- Fixed unable to drag infographic cards using iPad.
- Fixed blank parameters when choosing a geography level on ENRICHBYGEOGRAPHY Function builder.
- Fixed blank page loading after switching connections using Function Builder.
- Fixed connection summary not loaded after resetting map with IWA/LDAP/PKI sign-in.
- Fixed the apostrophe at the start/end of the layer name causes the attribute table to not load.
- Fixed failure to delete features corresponding to a deleted row.
- Fixed fields display incorrect information unrelated to their corresponding Excel row when viewing pop-up.
- Fixed function not written in the expected cell when using Function Builder.
- Fixed deleting column operation causes non-read properties of null error when using GETCOORDINATES Function.
- Fixed unexpected selection when selecting a column/row for a single cell function.
- Fixed True/False values for certain attributes in the Function builder causing anor message to display under the attribute's textbox.
- Fixed incorrect selection results when selecting more than one row under the Map Data tab.
Quality of Mapping:
- Sign-in dialog UI and error messaging improvements.
- Increase the time-out period for inactive maps.
- Corrected color theme for Reset map and Function Builder icons.
- Update telemetry for ArcGIS for Excel.
- Select option under Map data is grayed out when clustering is enabled.
- When GE service is disabled the GeoEnrichment functions in Function Builder will be grayed out.
- Tables, cell range, and pivot tables are distinguished when toggling between Active layer dropdowns.
If there are areas of improvement for ArcGIS for Excel that you would like to see covered in a future blog, please provide your feedback to Esri Community. Also, check out my Story map for additional hidden gems.
