Synchronization Failed?
851
05-25-2022 08:40 AM
DerekBannon22
My synchronization is saying that it failed, but it actually updates properly.
I have pasted a clip of my command line that shows what I am seeing when I try and synchronize edits.
I am not sure why this is happening. I think it has something to do with the "eInvalidContext..." statement in the command line, but I do not know what that means.
After this action the Web Feature Layer that was synchronized is visible in model space, but it cannot be interacted with. You cannot click on it or select it. Also AutoCAD will crash if you try opening the attribute table of any Web Feature Layer or Document Feature Layer.
Synchronizing... ...
Synchronizing Field_Topo...
0 features deleted...
0 features added...
1 features updated...
eInvalidContext...
Synchronizing failed Field_Topo...
**** System Variable Changed ****
1 of the monitored system variables has changed from the preferred value. Use SYSVARMONITOR command to view changes.
**** No System Variable Changed ****
Command finished...
Synchronizing complete. ...
