Full domain list is not pulling when layer is added via plug in.
1822
11-16-2022 03:07 PM
MonikaWheat88
Okay so when I am pulling online layers into AutoCAD the table is only giving me two names within my Status(Type) Domain. When I pull the same layer into Pro it maintains the entire list. Does anyone know what I have done incorrect to have it not read the entire domain? Some of the list was generated in the online environment not exported out to the hosted feature layer.
First two photos are what is pulled from Pro and last photo is the same layer with available options in AutoCad. Any advise?
DanWade
Hello @MonikaWheat88,
I appreciate the URL for the service in question. If we review the fields we see the field named "TYPE" contains the domain names we are looking for. However, scrolling down the REST page just under these fields to the TYPE heading we see there are only two of the five domains we are expecting (Additional and Main). ArcGIS for AutoCAD is reading from the REST endpoints TYPE section to determine the domain list.
Perhaps you can determine what caused this during publishing, but if not I would suggest calling Esri Technical Support > Enterprise Usage. The Enterprise EXT team would support ArcGIS for AutoCAD.
Let me know if I can be of any further assistance.
Kind regards,
Dan
DanWade
First, thanks for using ArcGIS for AutoCAD! I did a quick test using a short dataType field and text dataType field with no issues when the layer was added to AutoCAD.
Would it be possible to get the REST URL to this layer you are experience this behavior? You can send me a private email if you do not want to post it here. Otherwise, I suggest you contact Esri Technical Support for assistance on this post.
Kind regards,
Dan
MonikaWheat88
I am happy to give you the REST URL it is on the enterprise system. is the email on your profile?
DanWade
Kind regards,
Dan
MonikaWheat88
Thank you so much!
