ArcGIS for AutoCAD, on AutoCAD 2015
8659
13
05-29-2015 03:39 PM
surens
ArcGIS for AutoCAD; AutoCAD 2015. Can anyone say me when is it going to release..??? as none of the arcgis versions are compatable with the 2015 autoCAD version..
Tags (1)
DonKuehne
Navaneetha,
Depending on what you intend to do with the .DWG you may not need to export anything.
ArcGIS Desktop (ArcCatalog/ArcMap/ArcGIS Pro) will read the DWG you’ve created with local feature classes as an ArcGIS dataset with those feature classes and attributes.
If you want to create a shapefile or copy the data to a geodatabase you certainly could also do that in Desktop with any GP tool or other method that copies GIS data (since the local feature classes in the DWG already are a GIS data set with attributes etc.)
-Don
Navaneetha_KrishnanAsokan
Some time's need to save the drawing once again in some other path for exporting the feature classes, in the original drawing where feature class (local) is created is not visible in catalog.
Otherwise it is good.
Is there any other tool to update the field in the feature class (local) automatically
Is it possible to access WMS or WFS service rather than Arc server rest api's.
DonKuehne
Navanetha,
No ArcGIS for AutoCAD, does not support WMS or WFS, it is a free client of ArcGIS Web Services which have more capabilities than their OGC counterparts especially within the ArcGIS System.
-Don
