Annotative block rescaling upon synchronization
1155
11-23-2022 09:48 AM
jmaxwell_braun
I'm using an annotative block to symbolize points in a hosted feature layer using ArcGIS for AutoCAD. After I synchronize, the blocks are rescaled based on the annotative scale. So basically they become huge (i.e., if the annotation scale is set to 1" = 80', the scale of the block changes from 1 to 80 after I sync).
I can avoid this issue by setting the annotative scale to 1" = 1' before I sync, then changing it back. Is there any other way to avoid the rescaling issue? It's easy to forget to change the annotative scale before syncing each time.
The block units are set to feet. Coordinate system is state plane, feet.
AutoCAD 2022, ArcGIS for AutoCAD 410.
Thanks!
DanWade
Hello JMaxwell,
Thank you for using ArcGIS for AutoCAD. We appreciate you bringing this behavior to our attention.
We are taking a look and hope to have a fix.
Kind regards.
