Observe the Symbology of the Feature Service
1071
08-01-2022 02:10 PM
Status: Closed
TedCronin
If I have a Feature Service, with its own symbology defined, can we utilize that same symbology when we add the Feature Service into A4A, it seems like it applies a default symbol set rather than displaying the symbol that was published with the Service.
2 Comments
Randy_Garcia
Status changed to: Closed
Unfortunately ArcGIS symbols and AutoCAD symbols are not compatible.
ArcGIS for AutoCAD does give you the ability to apply symbol on a point layer to use and autocad block instead of a point. You could then create a block that resembled the ArcGIS symbol and use that in AutoCAD as the symbol.
TedCronin
This is unfortunate.  We will use the symbology from Map Services and just use the Feature Services as Operational and interactable
