Site Scan flight or manager application access.
2100
08-24-2022 02:11 AM
ZatilHoesna1
1. Does the login to Site Scan Flight/Manager works the same as ArcGIS Online? Like is it possible to log in to Site Scan simultaneously (of different user/login)
2. Can multiple projects be processed by Site Scan simultaneously?
Tags (1)
NicoBonnafoux
Hi @ZatilHoesna1 ,
Site Scan licenses are named-user licenses, so a same license should not be used simultaneously. But yes, many users can be logged in simultaneously and there is no restriction on how many missions can be processed simultaneously, the servers scale automatically based on load.
Andrew-Bowne
1:  you can link Site Scan Manager to your ArcGIS Online account.  That will allow using the same username and password for both.  You can configure this under "User Settings" for your organization in Site Scan Manager.
2:  Yes, you can process multiple missions at once.  I don't know if there is a limitation but I can say that I have processed 3-5 missions all at the same time.
NicoBonnafoux
Hi @ZatilHoesna1 ,
ZatilHoesna1
Hi @NicoBonnafoux
Many thanks for this!
