Daisy-chain multiple missions
6206
12
07-08-2021 08:12 PM
Status: Open
LanNguyen1
We need to fly over multiple small plots and I know someone can use UGSC to do this job efficiently with only 13 photos taken on each plot, 1 battery (25 min). Photos on each plot then stitched together to create ortho img for each plot.
We have access to SiteScan flight planner and hope that it will have this feature soon.
Lan
12 Comments
NicoBonnafoux
This is still a functionality we want to add, but currently the priority is our efforts on releasing an Android version of the Flight app so this is on hold.
All your feedback is appreciated, please be sure to "Kudo" the idea if this is of interest to you, thank you.
Jake
It would be great if Site Scan could allow users to select more than one flight mode in one flight plan.
Normally, when planning a flight in Site Scan Manager for ArcGIS, it allows the selection of only one flight mode per mission. However, there are instances where planning flights with different modes in a nearby area is necessary. Currently, the limitation exists where only one flight mode can be chosen for a single mission. This requires users to recall the coverage of the first flight plan and manually select a second flight plan to ensure overlap. It would be beneficial if Site Scan Manager allowed the creation of multiple flight modes within the same project and provided the option to set overlap between these flight modes.
Jake
