Utility Network Associations Viewable on Field Maps
571
10-07-2025 09:17 AM
kcoonen
With the latest release of Field Maps being compatible with Utility Network version 7, when is there going to be a release to be able to view the Associations linked to a feature class the same way you are able to view related tables on Field Maps?
JeffShaner
We're planning to support Association pop-up elements in the first half of 2026.
kcoonen
Is this going to be for all UN, because this will be huge for Communication/Fiber UN? Or is it going to only be a select few like this: https://doc.arcgis.com/en/field-maps/android/use-maps/utility-network.htm#ESRI_SECTION1_EFC2102C2C36...
