Using a related table as a lookup to create a dropdown for a field
639
05-05-2025 08:24 AM
KatieQuantrell
I've created a Field Maps form that contains several pairs of linked fields, e.g. depending on the value selected from the dropdown in the first field the values available in the dropdown of the second field differs.
I've currently set this up using contingent values via ArcPro. However despite it working well for domain lists that only contain a few values, for one set of fields in the form there is ~700 contingent values causing the dropdown for the second field to be very slow to load (around a minuet), making the form un-useable.
I'm hoping to find an alternative solution to using contingent values in this case therefore and was wondering if there is a way to use a related table as a lookup to set up a dropdown for a linked field?
Any help/advice would be really appreciated.
Thank you
