Track When Field Maps Offline Data Is Synced
1631
12-03-2025 09:05 AM
JesseSchewe_mnr
In my organization, we rely heavily on Field Maps and collect data almost entirely on offline map areas. In a given day, we have multiple users in the field collecting geometry (points, lines, polygons) on the same offline map area. However, at the end of some days, our field users forget to sync their offline map areas to put the data that they collected into the online web map. When performing data QA/QC the next day in the office, it can be hard to tell why a field user doesn't have data for the previous day -- did they just not find anything, or did they forget to sync?
Is there a way to track or a log that can be enabled or viewed or that shows when Field Maps users have synced to either a specific offline map area or any offline map area associated with a web map?
Thanks
DougBrowning
MVP Esteemed Contributor
I have this script that works.  Gives user, last sync, etc.  I use it to find old replicas to delete since Field Maps has a bug for some time now where any replica removed while offline gets orphaned.
Just make sure Pro is logged in.  Does not have to be open just in.
Hope that helps
import arcpy
from arcgis.gis import GIS
import arcgis
from arcgis.features import FeatureLayerCollection
gis = GIS('pro')
#gis = arcgis.GIS(profile_name=profile)
#itemID of service
itemID = "acbb9fa63afdafc9fsd0b16"
item = gis.content.get(itemID)
flc = FeatureLayerCollection.fromitem(item)
replicas = flc.replicas.get_list()
print ("ReplicaOwner,ReplicaName,ReplicaID,CreateDate,LastSyncDate")
for r in replicas:
    replica = flc.replicas.get(r['replicaID'])
    create_date = datetime.datetime.fromtimestamp(replica['creationDate'] / 1000)
    last_sync_date = 'n/a' # don't trust this to always be populated
    if type(replica['lastSyncDate']) is int:
        last_sync_date = datetime.datetime.fromtimestamp(replica['lastSyncDate'] / 1000)
DougBrowning
Hope that helps
import arcpy
import arcgis
gis = GIS('pro')
#itemID of service
for r in replicas:
JesseSchewe_mnr
Hi Doug,
Thank you for your response! This sounds like it would be helpful. I have a few questions.
  • Where is it that you are running this script?
  • What are replicas in this instance?
  • Our maps are composed of ArcGIS Online hosted feature layers, and we do not use ArcGIS Enterprise. Does that have any bearing on this matter?
I'm still getting used to the online Arc environment and all help is appreciated!
Thanks
DougBrowning
I use this for AGOL services so it should work fine.
You will need ArcPro installed and logged into AGOL.
Get a Python editor - I use PyScripter.
Change the itemid to that of your service.   Get this from the AGOL page.
Run it
You can also view this manually by going to the item page of the service.  Then bottom right you will see a link to the REST service page.  Click that and it opens a text based interface.  Look for Replicas at the bottom and in there you can get a list.  Replicas are what Arc uses to checkout data onto the tablet.
What you are asking is a bit advanced but you should see it if you poke around.
Hope that helps
JesseSchewe_mnr
Hi Doug,
Thanks for expanding! This is a really good start for what I'm trying to do, and I appreciate you sharing your knowledge. I have a long way to go in learning all the ways to interact with AGOL; it's nice to know folks are willing to help.
All the best!
