templates/default values for non-spatial tables?
5351
11
10-05-2022 03:58 PM
PaulPetersen1
I have a Field Map in which the user collects facility inspection data within a related (non-spatial) table. I'd like to set default values in the related inspection table, but it appears that I have to create and set up a template in order to do so. And it also appears that I can only create templates for spatial layers. Thus, it looks as though there is no way to set templates (or default values) within a non-spatial table in Field Maps. Am I missing something?
(yes, I know I can use arcade to calculate a default, and that is my fall-back)
BTW, I'm using hosted feature layers in AGO.
Sean_Haile
They are definitely honored in field maps when published using a federated server, I assume they would also honored by Field Maps when using hosted services in AGOL.
CraigGillgrass
Yes, @PaulPetersen1 they will be.
