Sync failed - Insertion failed because database is full
2741
7
12-16-2021 01:04 PM
RiainGarcia
Working with failed maps offline, attempting to sync at the end of the day and received the following general error
"Insertion failed because the database is full"
Tags (3)
RiainGarcia
It's still not working. This first occurred on Wednesday 15th, circa 9pm GMT
Kanin
by Esri Contributor
Hello,
Are you using ArcGIS Enterprise or ArcGIS Online? If it's the former, please check (or ask your admin to check) whether the ArcGIS Data Store is full and is in read-only mode.
More details: ArcGIS Data Store command utility reference—ArcGIS Enterprise | Documentation for ArcGIS Enterprise
If the data is registered to an enterprise geodatabase, ensure that the RDBMS server is not full as well.
Best regards,
Kanin
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
RiainGarcia
Thanks for the reply
We are using ArcGIS Online
RichlandGIS
was this by any chance on Monday morning?
some of AGOL's data servers were "down" for the first few hours of the morning on Monday.
their status page says it was up and running, but it was not.  I could view Item details on my hosted layers, but, no data tab/data, and error messages saying it couldn't find something, and nothing was working correctly.
an hour or so later, it was back up.
Have you tried again just to see if it was during the undocumented outage?
R_
RiainGarcia
Kanin
by Esri Contributor
Can you try the same workflow with another (ideally simple) feature layer hosted in ArcGIS Online to see if it is data-specific or not?
AdamJBoczek
Any chance your tablet/device is completely full?
RiainGarcia
No it wasn't Adam
