Switch Unable to set Default Values
103
Monday
JoshuaRomer
I am making map for boundary closures. So I have a feature layer with points taken from a spreadsheet, and the form I'm using is a switch, to show if a site is currently open or closed. I noticed that I am unable to set a default value, and when I tested it on Field Maps, I can switch a point to "Closed" but setting it back to open gives me a "No Value." I looked under Templates, and I have 2 values, "Open" and "Closed." I'm trying to have "Open" as a default value, but all options to set a default value is unavailable.
EmilyGeo
Hi @JoshuaRomer
I'm not sure why you wouldn't be able to set the default value.
  • Did you try setting the default value in the Templates tab in Field Maps Designer?
  • Can you post a screenshot of what you see there?
