SQL UPPER works in Filter function but TRIM doesn't
1380
12-21-2023 12:44 PM
HollyTorpey_LSA
I'm working on an Arcade field calculation in Field Maps. I'm working in the Map Viewer.
This works:
var projectSoilPits = filter($featureset, "UPPER(ProjectNumber) = @projectNumber")
This doesn't :
var projectSoilPits = filter($featureset, "TRIM(ProjectNumber) = @projectNumber")
Neither does this:
var projectSoilPits = filter($featureset, "TRIM(both ' ' from ProjectNumber) = @projectNumber")
Both result in a "Failed to calculate" error when I test the form in both the Map Viewer and the mobile app.
Can someone please tell me why the SQL-92 UPPER function is working for me but TRIM isn't? Thanks in advance!
- Holly
DougBrowning
It is probably that SQL is not fully implemented in all tools.  Plus what is implemented varies between, SDE, GDB, in memory sets, AGOL, Map Viewer and ArcPro/ArcMap.
I have asked a few times over the years for documentation on any of this but never got a response.  Makes it hard when you are just guessing.  Sometimes the syntax is also different.  Esp true with in_memory and memory in Python.  My guess is that Arcade is also not full SQL
Just some of the posts on this.  Sorry not a great answer but it may be better to look for another way like contains maybe?
 https://resources.arcgis.com/en/help/main/10.2/index.html#/SQL_reference_for_query_expressions_used_...
Many posts on this
https://community.esri.com/t5/python-questions/cast-does-not-work-in-searchcursor-queries/m-p/264322
https://community.esri.com/t5/arcgis-online-questions/new-map-viewer-and-classic-cannot-handle/m-p/1...
https://community.esri.com/t5/data-management-questions/using-sql-cast-functionality-in-against-a-fi...
https://community.esri.com/t5/arcgis-pro-questions/are-def-query-using-sql-now-different/m-p/85499
https://community.esri.com/t5/python-questions/sql-clause-in-arcpy-da-searchcursor-is-not/m-p/51603
https://community.esri.com/t5/geodatabase-questions/what-sql-commands-do-in-memory-workspaces-suppor...
