Shared Update Groups and Manage Offline Map Areas
5732
10
03-29-2021 12:49 PM
kmsmikrud
Hello,
I'm not sure when 'Shared Update' Groups came online, but today is the first time I've had an AGOL group get labeled with this. The settings I've previously set for other groups is with membership only available to the organization and then the following.
This group is for use with ArcGIS Field Maps in which members need to edit the feature layers. We also need the ability to manage offline map areas. I am able to do this in other established groups with folks editing data and web maps shared to the group where I manage offline map areas.
I have created/deleted this new group I would like to create many times already this morning trying to figure this out.
How can I have a web map shared to a group where group members can update the items in the group and I can also manage the offline map areas for use in Field Maps?  I have been doing this for other groups over the last year without this 'Shared Updates' label and offline map areas? Today is the first time I've received this new 'Feature disabled' notice. So I'm supposed to unshare and reshare each time I want to create a new offline map? What is going on?
Thanks in advance for your help,
Kathy
HelenLin
Hi Kathy,
I am coming across the same situation and wonder if you eventually sorted it out.
I think my situation is a bit more complicated as I don't own the map and I am only able to edit the map because of the shared update group. And I wanted to create a new offline area because the existing offline area failed to download on devices (which seemed like another weird situation that many had...). Wonder if anyone knows how to solve the situation?
Cyprus_Forest_Department
Hi to all! Have you figured that out yet? I stumbled upon it today. Same scenario. Do we have to erase the group and create a new one?
Katie_Macintyre_Atmos
I've just come across this too. I was trying to enable colleagues to update webmaps I'd created by sharing them with a shared update group but then I lost the ability to manage the offline areas myself, even though I am the webmap owner. Did anyone find a fix for this, or is the only way to manage offline areas to log in as the map owner? This seems like a strange limitation.
The solution is to wipe the group, create a new one and enable this
Cyprus_Forest_Department_0-1680240474717.pngCyprus_Forest_Department_0-1680240474717.png
ToriK
I am running into this issue now too. Did anyone figure it out? The solution posted by Cyprus Forest did not work for me.
Group members are still unable to add offline map areas themselves.
No I'm afraid not. Wiping the group and making a new one with the 'All group members can contribute' option left everyone, including me, unable to create offline areas. The only solution we've found for other team members to create offline areas is to log in as the map owner which involves sharing passwords so not really a solution.
SierraNevada
It is 2025 and I just had this begin happening to me after creating offline map areas for years without the error. I do not even need to have the "Shared Update" setting enabled for it to trigger. It is triggered by any group setting that combines sharing outside of the organization with allowing all members to contribute content. My colleagues do not have this limitation, so my guess is that it is a setting on my own account or licensing. I will update if I figure out which one.
nick_red
I have the same thing, I am an admin and this error not allowing me to create a offline area came out of no where. Any solution besides unsharing with group?
Kevin_MacLeod
did you change something? I'm in the same boat, I don't think anything changed.
Did Esri break/change or "improve" something with a recent AGOL update?
