Related Tables Conditional Visibility Field Maps Application
1211
03-31-2025 11:17 AM
JulieCulligan
I have a set of related tables I would only like one related to show based on a filled out field- it works on the map level, but not the mobile application.  ArcGIS enterprise.
IE.  The parent table contains type, which based on the type Bathroom, I'd like it to show a the related inspection table called bathroom.  It works on the map level, only the bathroom inspection shows up, but on the field maps mobile application it shows, bathroom, living room, ect. (all my related tables)
How can I just get it to show bathroom on the field maps applications (all tables will be used in the map, so removing them will not work).
ChristopherCounsell
MVP Frequent Contributor
The documentation is a bit misleading here as it outlines how to create related record elements in map viewer.
https://enterprise.arcgis.com/en/portal/latest/use/create-form-mv.htm#ESRI_SECTION2_71A3B3BF89884353...
Unfortunately related record elements are not currently supported in Field Maps.
https://doc.arcgis.com/en/field-maps/11.4/prepare-maps/configure-the-form.htm
While related record elements added to the form will appear in Field Maps Designer, they cannot be formatted and will be hidden from the form in the Field Maps mobile app.
It's slated to be released soon:
https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/whats-new-in-arcgis-field-maps-f...
ChristopherCounsell
JulieCulligan
Thanks Christoper- getting excited for the next field maps releases. They will have a major impact on the way we work.
