Reduce repetitiveness when capturing multiple similar features
1626
05-03-2022 04:53 PM
OliverIshmael
At the end of a form, I would like a radio button question to ask the user whether they wish to submit another form for a similar feature:
Yes - the current form is submitted and a new form is displayed with some fields pre-populated based on the answers in the current form.
No - the current form is submitted and closed.
Can this be achieved in any way.
Many thanks for your advice
nspittlemeister_LCFPD
Have you tried using the copy button to copy existing features and ones just submitted? See link below.
https://doc.arcgis.com/en/field-maps/android/help/capture.htm#ESRI_SECTION1_7592E6B5E66C40E7BA62991E...
ArmstKP
I wish this was possible in Survey123 as well.
If I flush 1300 hydrants, would be nice to click or circle them all, so I only have to enter once, instead of 1300 times, which would take a full week to do....
Field Maps has the option to select multiple or you could use ArcGIS Pro to select the hydrants and calculate values.
