Recommendations for GNSS receivers for use within ArcGIS Field maps
255
02-18-2025 05:32 PM
NigelGriffiths
Hello, I am just after some recommendations for GNSS receivers with RTK capability. We are considering purchasing a Carlson BRx7, but I have noticed it requires a separate application (Carlson Layout) to enable mock location, while our previous unit (Septentrio Altus NR3) was able to be selectable as a receiver directly.
Does anyone have any experience with other GNSS receivers that work well in ArcGIS Field Maps for ~1cm level accuracy field collection, or with the Carlson BRx7 directly?
RTPL_AU
@NigelGriffiths Start with the receivers listed explicitly as compatible and then check what you can get local to you from a store with proper support.
https://doc.arcgis.com/en/field-maps/latest/prepare-maps/high-accuracy-data-collection.htm
If you want to get a device with built-in LTE/5G note that the switch-off of 3g in some places has made things complicated if the manufacturer has not pushed an update to disable 2g/3g fallback.
I've heard very good things of Emlid receivers.
