Read-Only and Editable Fields and Layers in the Same Map - ArcGIS Field Maps
4876
06-30-2021 06:13 AM
JasminePrater
Occasional Contributor II
I have several maps I created in ArcGIS Pro 2.8 that I have published as a service to our ArcGIS Server.  I have these maps on ArcGIS Online and pointing to our server, and they will be accessed through ArcGIS Field Maps.  There are a few layers that I do not want our field crews to edit, as they come from an outside data source.  Is there a way to publish the map with a combination of editable and read-only layers, or do I need to put the read-only layers in a separate map and add the layers to the map in ArcGIS Online?  I tried using the List by Editing option in the Contents pane, but all layers are still editable.
Additionally, there are several layers that have attributes that the field crew supervisors do not want to be editable, while other data in the same layer is editable.  Is there a way to make specific attributes read-only, while other attributes are editable?
Thank you!
DougBrowning
This is all for map viewer classic not sure on the new one.
You can turn off editing for a layer in the web map.
I think you can also create a feature view but that is more complicated.
For attributes you set that in the popup.
I use this so a field map can edit certain attributes and layers while the office map can edit other attributes and layers but it is all the same feature service.
Hope that helps
DougBrowning
Hope that helps
JasminePrater
Yes, thank you, Doug!  This is exactly what I needed for both problems.  I really appreciate it!
