I am hoping to use an old (but not that old) Samsung Galaxy A51 5G with Field Maps for our crew completely offline as it will be used in remote locations. I don't want it to have to depend on the crew using their personal phones as a hotspot to operate, or ask them to install and use Field Maps on their personal phones. The phone is an old personal phone of mine that was wiped and has just Field Maps and other basic apps installed. It has a SIM card but is not on a network. Location is turned on. Offline areas are saved and appear to be working correctly when downloaded from Wi-Fi. I assumed GPS would work fine without any connectivity but I'm having issues.
When I select "Start Streaming", the GPS accuracy is listed as 4.7 m, and I have "Accuracy" under "Collection Settings" set to 50 m. However, the message at the top reads "Point not collected" even though it appears to be getting an accurate enough fix. I have let the device attempt to record for 10+ minutes without success. When "Start Streaming" is selected, a pop-up message appears that says "Streaming will resume once your position updates". Under the phone's Location settings, I turned off Wi-Fi scanning and Bluetooth scanning as the phone won't be using this anyway, this doesn't seem to affect the ability to record points either way. I am testing the phone outdoors under open sky, but under "GPS details", it lists 0/10 under "Satellites (used/visible)". The same map works fine with other connected devices. What's going on?
Hi @AndrewBraun , you dont seem to be running into an accuracy constraint but rather the position coming from the GPS is stale. If you were falling outside of the required accuracy the message would be slightly different. If you tap to open the GPS details there is a row right at the top that shows when the GPS was last updated ie "Updated just now". What does this say for you when you receive this message? Is you location dot on the map blue or grey?
