Potential bug - cannot populate attribute from view table registered to enterprise database
693
07-29-2024 05:53 AM
RPGIS
by MVP Regular Contributor
I believe that there might be a potential bug regarding attribute rules and field maps. I have an editable feature service in field maps that has an attribute rule which populates information from a view table of another server sde table. The rule executes fine in pro but it does not execute in field maps.
When executing in field maps, I get the following error message:
  • 'Unable to execute attribute rule <name>. Table cannot be found.
I have tried toggling "Exclude from application evaluation" to see if that would fix the issue but to no avail.
Has anyone else encountered similar issues when working with views created in sde?
