Possible Bug: Field Maps will not work properly with an 'empty' Feature Layer
1506
06-02-2021 03:29 PM
BlairDeaver3
I am logging what appears to be a bug/software defect with Field Maps and Feature Templates.
Problem:  I was unable to prepare a map for offline use when the Web Map referenced an empty Feature Layer with no records - and thus no Feature Template.
You will get an immediate failure message when preparing the managed map areas or manually downloading the map areas from the phone.
Solution: Create a new feature (and thus the Feature Template) before preparing your Field Map app for the field.  You can delete the point after.
Environment:
  • AGOL
  • Field Maps for iOS (App Version 21.1, Build 396)
It would be great if this was better documented in online tutorials/help.  Thank you
Cheers,
Blair
by Anonymous User
Not applicable
I'm not able to reproduce this using a simple Feature Layer Template from ArcGIS Online.
How are you publishing/creating your layers?
Are there multiple layers/tables in the feature service?
Do your layers have Feature Types or just templates?
These are hosted layers, correct?
What is the exact error message are you seeing?
