Packaging Map Area for offline Failed- HTTPS Hostname Wrong
560
07-27-2023 06:37 AM
Andrew-Bowne
I'm trying to package some map areas for offline use.  Every attempt at packaging is resulting in Failure.
When I look at the Portal log file, I see the following error:
Failed to add item <ITEMID> from URL <SERVERURL>
HTTPS hostname wrong: should be <SERVERURL>
<SERVERURL> is the URL to a server federated to our portal.
Not sure what's going on here.  Help?!
