Open a URL based on value in Form
1481
11-21-2024 03:11 PM
MeleKoneya1
Hello,
We are migrating our hydrant review app to field maps.
Part of the current Web App Builder is the ability to launch our own work order URL when a repair is needed.
The URL passes in the asset_id as an argument and the web page opens allowing fire crews to update the issues they may have found in the field.
Can I do with this a field maps form?     I have a  review status field in the form where one value is 'Needs Repair'     When that is selected, I would like an action to open the web page.
Thank you,
Mele
ChristopherCounsell
MVP Frequent Contributor
Yes you can do this with an Info note and expression. Here is a guide that will run you through the steps:
https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/add-read-only-information-to-for...
ChristopherCounsell
MeleKoneya
This is great!     I am able to add the info element and make it conditionally available.    For some reason, I do not see the expression I created and only the attributes of the layer.    Is there a particular place to add an expression that uses a value from the layer for use in the URL?
MeleKoneya
I found a way to do it.   I added a field to the form and created an expression for the URL.    I then hid the field and saw the expression in the Info element when I went in to configure it.
ChristopherCounsell
Perfect! You can add expressions but not use them, then use them elsewhere
in the form.
https://doc.arcgis.com/en/field-maps/latest/prepare-maps/configure-the-form.htm#ESRI_SECTION2_5F65DF...
Glad it worked. I also learned something new so thanks for posting!
