Only owner of feature service layer can make edits in Field Maps
496
10-13-2023 09:13 AM
PeteVitt
Occasional Contributor III
Hi - I've got a Field Map with a form tied to a feature service layer.  I want to make the feature service layer editable for all users.
I've enabled public data collection and shared the feature service layer with everyone.  I've also shared the Field Map with everyone.  Is there some other setting I need to configure to enable users other than the owner to make edits to the feature service layer?  As it stands now only the owner of the feature service layer can make edits
Thanks
Pete
Tags (1)
PeteVitt
Hi - Tech Support solved the problem.  The issue was that the user I was logged in as was a field worker with 'Viewer' Role.  When I changed the role to 'Data Editor' the issue was solved
KenBuja
MVP Esteemed Contributor
Have you enabled Editing for the layer? This is found on the item's Settings page, under "Feature layer (hosted)".
PeteVitt
Hi Ken - yes I have selected the Enable editing option in settings
Thanks
Pete
PeteVitt
