Offline packaging fail
2405
8
04-18-2025 09:06 PM
Y_Chau
Offline packaging fails for a dataset I want edit in Field Maps. Using Enterprise 11.4, only archiving is enabled on the dataset, no versioning. Server log produces this warning for 4 layers in the feature service -
Warning: RelationshipClass: INTDB.DBO.<layer> ATTACHREL: inputCount: <no. of records>. Keyset-based join Query for SRC. GetObjectsRelatedToObjectids failed
Please advise how to fix this.
Sincerely
HannesVogel
did you enable GlobalIDs before activating attachments?
Y_Chau
Yes, and the relationship to attachment tables is based on GlobalIDs.
DanielFox1
@Y_Chau
What size are the attachments? Are you able to package the area without attachments?
If you don't need attachments here is the documentation on how to remove them
https://pro.arcgis.com/en/pro-app/tool-reference/data-management/remove-attachments.htm
Y_Chau
Hi @DanielFox1
I want to collect attached photos but there are no attachments still. About 15k records only. When I disable attachments and try to package, it fails. Surprisingly no error in logs even after increasing the logging level to debug.
Sincerely
DanielFox1
Y_Chau
Yes, it checks all the bullets. I have done it many times. It was actually working fine in 11.3. Then we upgraded and also made some schema changes. We rolled back the schema changes and still can't get rid of this problem.
Even if I remove attachments I can't take it offline. Now it doesn't even leve any warning in server logs.
TimMcVey1
Did you happen to ever find an answer to this issue? We are dealing with the same thing right now, same setup and results.
Y_Chau
Yes, applying SSL certificate in every possible place worked in our case. Image server was on a separate machine. It worked only after we applied SSL on it.
